Forums >> General Discussion >> Wishlist >> MAXWELL RENDER SUPPORT PLUGIN!!
Fri, Jun 29, 2007 at 1:32:52 PM | MAXWELL RENDER SUPPORT PLUGIN!!
elvis
Hi all,
EVERYONE SEES THIS ONE COMING NOT!
WHISHED:
a maxwell renderplugin for revit! this doesn't seem to be that difficult, cause the external [maxwell] renderer is automatically launched if you hit the render button in REVIT [like in 3ds max] ,
So you only have to apply maxwell materials to your revit model in revit which have the correct UV coordinates!,
there is not even an viewport mode needed that shows the materials in REVIT [like in MAX, you see the mapping only simplified in the max vieport].
 The external renderer does all that! Ow, yes the export from revit is in [the allready excisting] dwf or dwg format, so that data [with UV coordinates embedded] is allready excisting! [dwg linking for max and viz]
 So, people, start working on it! can't be that hard!
Otherwise, there is only a material-library support needed so that through 3ds max you can activate maxwell. Now Revit  links a model to max with REVIT materials, change this to a maxwell material library! then your max model allready has the correct materials and UV applied! [this still includes max as an intermediate], but what the heck, JUST MAKE IT WORK!
ARCHITECTURE , BIM, STRUCTURAL AND NOT A GOOD RENDERER!! IT's A SHAME
Maxwell render plugin for Revit
Wed, Apr 20, 2016 at 12:15:53 PM
maxwell installation error!!!!! sos
Wed, Aug 20, 2014 at 3:56:23 PM
13
Addin: Projects used with previous version of plugins not compatible.
Sat, Apr 13, 2013 at 4:38:33 AM
Maxwell Render for Revit
Thu, Aug 31, 2006 at 6:05:54 PM
Render plugin for revit
Mon, May 12, 2014 at 7:03:52 AM
Page generation time: 0.1762
