Forums >> Revit Building >> Technical Support >> Can graphic overides allow "translucent hatching"
Fri, Jun 29, 2007 at 11:33:58 AM | Can graphic overides allow "translucent hatching"
wayline
In an effort to set up a consistant visual standard for Structural Plans for our small firm...*help*
The basic idea is that I would like to set my cut plane 5' above the slab, see a (transluscent) hatch for the wall, a (transluscent) hatch for the slab, and dashed lines for the footings.  I would obviously like to set the graphic overides / color scheme do this with little to no linework so that the model can do the talking.  Am I grasping at straws?
Fri, Jun 29, 2007 at 2:32:58 PM | Can graphic overides allow "translucent hatching"
wayline
using revit architecture 2008, by the way
Phase Graphic Overides
Tue, Sep 18, 2018 at 8:42:53 AM
Suggestions Appreciated...
Mon, Jun 29, 2009 at 10:45:24 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Cut Plane display issue
Fri, May 7, 2010 at 1:59:35 PM
Translucent Existing Phase after Rendering
Sun, Sep 28, 2014 at 7:08:34 AM
Page generation time: 1.0368
