Forums >> Revit Building >> Technical Support >> IFC file import
Fri, Jun 29, 2007 at 9:27:17 AM | IFC file import
Urbaneagle
I have tried importing IFC file by File>Import/Link>IFC in Revit 2008. I am not sure what’s wrong but the file does not import in to project. Please share your thoughts. Thanks
Fri, Jun 29, 2007 at 10:09:29 AM | IFC file import
Urbaneagle
Never mind.
I have tried ifc 2x model and that worked like charm.
Thanks,
Tue, May 4, 2010 at 12:43:52 AM | IFC file import
saif33943
I have tried both ifc 2x and ifc2x3, but failed to import any file.
Got an error message for both the format: "The following problems were encountered in the IFC file: Error    20056: Error opening  the temporary swapfile!"
 can anyone please help me to get out of this.
Tue, Jun 28, 2011 at 5:09:36 PM | IFC file import
revitw
Hello saif33943, I got the same message when importing IFC files: "The following problems were encountered in the IFC file: Error    20056: Error opening  the temporary swapfile!"
Did you resolve this issue? If so, please provide some advice. Thanks.
Tue, Jul 26, 2011 at 3:15:08 AM | IFC file import
Fomenkof
I had the same error 20056, aperrantly it meens that your swapFile is not big enough. I fallowed instructions on this  link and increased size of a swapFile to recomended, after thet had no error message again, and no problems with importing IFC .
No Import - Maximum size of IFC imports?
Sun, Jul 10, 2016 at 6:56:30 AM
IFC import intoRST2010?..
Fri, Mar 26, 2010 at 2:07:17 PM
Revit export/import to IFC - ceilings and floors (ifccovering)
Mon, Jul 28, 2014 at 3:22:58 PM
IFC detail drawing into Revit
Mon, Nov 25, 2013 at 2:31:31 AM
Revit to Ifc to Third Party BIM Viewer
Tue, Dec 11, 2018 at 12:36:03 PM
Page generation time: 0.4985
