Forums >> Revit Building >> Technical Support >> Interior Soffits
Thu, Jun 28, 2007 at 10:03:38 PM | Interior Soffits
trhymans
I am new to Revit 2008 and am starting to understand a lot of the things.  One that I don't know what to do and haven't seen anthing in the tutorials and videos I have seen is a simple drywall soffit in a room.  Ceilings seem to give me the most problem in the early going.  I have had trouble w/ ceilings showing up in the ceiling plans.  I have quite a few different ceiling heights.  And then how to create a drop soffit.  I would appreciate any tips on how to create them.
 Thanks
Fri, Jun 29, 2007 at 4:44:52 AM | Interior Soffits
latemore
latemore Avatar
3 Stars: 2 Votes
ceilings are sketched to some extent very similarly to floors, if you select the 'sketch' option that appears, otherwise revit will attempt to place a ceiling within a set of walls.  something to watch - there are two types of ceilings and we use 'compound' mostly as you get better real ceilings, like floors and rooves.  also, i find it sometimes best to sketch ceilings in the RCP.  as regards a bulkhead which i think you are referring to, try a short height wall and join geometry.
Fri, Jun 29, 2007 at 8:09:43 AM | Interior Soffits
MrBob
3 Stars: 2 Votes
I just made my first bulkhead/soffit yesterday.  I did as latemore said - I made walls at the height of the sides and then I made a ceiling of just gypsum board and joined the wall to the ceiling.
Drawing gyp. bd. soffits @ an interior
Fri, Nov 5, 2010 at 12:20:28 PM
Do roof soffits really need to be scheduled?
Wed, Mar 10, 2010 at 5:57:08 AM
Soffits
Wed, Jul 15, 2009 at 1:33:19 AM
Paint material to stairs soffits
Tue, Oct 31, 2017 at 6:50:59 PM
view range for floorplan views
Tue, Sep 27, 2005 at 2:41:03 PM
Page generation time: 1.6417
