20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Column Grid Visibility
2 Posts No Rating |
Im in the process of editing drawings and I have run into an issue with the column lines. I want the bubbles and the start of the grid lines to appear above and below the plan but not to run through it. In AutoCAD i would simply make another viewpoint that showed just the column lines. Unfortunately, when I attempted this in Revit, the effect was not the same. I have attached an example of what i want the Column grid to look like. Any and all help on this topic would be greatly appreciated.
I had the same issue. What you need to do is select the Grid and Toggle the 3d/2d Extents. When it is set to 2d it will allow you to drag the grids separetly for that view. I am posting an image showing what I am referring to. HTH
column grid visibility |
Wed, Nov 15, 2006 at 3:43:13 PM
Column Grid Line Weight |
Sun, Aug 13, 2017 at 3:05:53 AM
Column to Grid |
Tue, Sep 8, 2009 at 4:09:31 PM
Column grid text too wide to fit in bubble |
Thu, Jul 1, 2010 at 8:32:06 AM
GRID AND SECTION VISIBILITY |
Thu, Dec 20, 2007 at 8:03:27 PM
