Forums >> General Discussion >> Revit Project Management >> Fixed values in schedules
Thu, Jun 28, 2007 at 8:16:45 AM | Fixed values in schedules
Luisa
I need to place fixed values of demolition and construction in my schedule and I do not know as to make it... Someone can hepl me? Smile
Thanks
Mon, Jul 9, 2007 at 10:34:14 PM | Fixed values in schedules
eldados
eldados Avatar
4.5 Stars: 8 Votes
while in the schedule, right click and go to properties.
under the fields tab in the middle there is a button called "Add Parameter"
the rest is self explainatory... Smile let's us know if your stuck Smile
Integrator
KarelCAD
Preloaded Size Values in Revit MEP
Tue, Aug 24, 2010 at 1:54:48 PM
Schedule totals are not calculated right: 1+1=1
Mon, Mar 5, 2007 at 2:24:08 PM
Schedules Apperance
Mon, May 19, 2008 at 8:19:23 AM
EQ Dimensions and Fixed Distances
Wed, Nov 27, 2013 at 1:26:36 PM
Combine two text values using a formula
Sun, May 13, 2018 at 5:57:05 PM
Page generation time: 1.4166
