Forums >> Revit Building >> Technical Support >> Applying a bitmap to an object
Sun, Jan 16, 2005 at 11:10:32 PM | Applying a bitmap to an object
meta4
3 Stars: 2 Votes
Can anyone help me with a problem concerning bitmaps applied to objects. Specifically can you get the bit map to always appea rcorrectly oriented. Studio Max does this with xyz coordinate system, does Revit have a similar function? I want my Koru to always be centered on the panel (see attached file). Cheers anyone who can help
Mon, Jan 17, 2005 at 1:11:41 AM | RE: Applying a bitmap to an object
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've never had the need to map something in Revit to an exact position like this so i'm not sure off the top of my head... I guess it would be easiest done using decals... This way you can set the exact size and location of the image manually and will be represented in shaded views with a crossed box so you can easily manipulate it. HTH.
Mon, Jan 17, 2005 at 4:11:54 AM | RE: Applying a bitmap to an object
Mr GG
3.5 Stars: 9 Votes
Mr Spot is correct - use decals in this case. --------------------------------------------------------------------- Trying to use bitmaps on materials is not that easy... Revit is not like VIZ or Max... I have had some tryouts: http://revitcity.com/gallery.php?action=view&gallery_id=228 http://revitcity.com/gallery.php?action=view&gallery_id=227 And this one: http://revitcity.com/gallery.php?action=view&gallery_id=333
Bitmap doesn't print
Mon, Oct 25, 2010 at 4:29:23 PM
Cone roof mapping
Thu, Mar 15, 2007 at 12:27:33 AM
Components
Wed, Dec 7, 2005 at 11:53:18 AM
3dmax bitmap path adding?
Thu, Mar 30, 2006 at 5:32:44 AM
Patterns and Shadows
Fri, Jul 5, 2013 at 12:44:28 PM
Page generation time: 0.1824
