Forums >> Revit Building >> Technical Support >> invisibility below grade
Wed, Jun 27, 2007 at 8:52:38 AM | invisibility below grade
vblevin
i"m new to revit (using 9.1). how can i get everything below the toposurface (grade) to be invisible in elevation and/or 3d views, for presentation purposes?
Thu, Jun 28, 2007 at 2:35:05 PM | invisibility below grade
RedRevit
I've been doing this with masking regions (under the Drafting section of the design bar).  This seems to be the easiest way, but it will not work for 3d views.
k
Thu, Jun 28, 2007 at 2:50:21 PM | invisibility below grade
RedRevit
k
Fri, Jun 29, 2007 at 7:52:46 AM | invisibility below grade
NightRyder
one option would be to duplicate your 3d/elevation view, rename it to something like 'above topo' or something along those lines and then just hide everything that you dont want to see in that view.
this way you'll still have a regular view that you can manipulate as you see fit, but you can revert to this other view for your presentation purposes and everything you want to be hidden should stay hidden
 just my .02
Fri, Jun 29, 2007 at 8:26:24 AM | invisibility below grade
NightRyder
 just my .02
Fri, Jun 29, 2007 at 8:30:29 AM | invisibility below grade
vblevin
masking region works well for elevation views. i'm still not sure how to do it in 3-d views. nightryder suggests hiding things below grade, but part of my foundation wall is above grade and the garde is very uneven so i couldn't even make a clean break in the foundation wall to hide it.
Fri, Jun 29, 2007 at 8:41:22 AM | invisibility below grade
vblevin
maybe, is it possible in revit to create a  cropping plane that would "crop" everything below the plane? or is the only solution  to model the topo surface so that in 3d views i would see dirt below grade ?
Fri, Jun 29, 2007 at 8:49:22 AM | vblevin
NightRyder
Quoting vblevin from 2007-06-29 08:41:22
"maybe, is it possible in revit to create a  cropping plane that would "crop" everything below the plane? or is the only solution  to model the topo surface so that in 3d views i would see dirt below grade ?"
yes...you can use a crop region to adjust what you see in the view...or you can use a section box and actually crop away parts of your model. depending on how non-uniform your topo is this may or may not work for you...you can activate the section box within 'view properties'...scroll down to 'extents' section and check the 'section  box' box. from there you can select the section box and drag the arrows around to mold what you want to crop...hope that made sense.
Fri, Jun 29, 2007 at 8:54:25 AM | invisibility below grade
vblevin
yes i understand what your saying nightryder, but the  box is square and my grade is uneven.
Fri, Jun 29, 2007 at 9:01:44 AM | vblevin
NightRyder
Quoting vblevin from 2007-06-29 08:54:25
yeah i figured that would be an issue...is it just foundations that you see under the topo? you could always try and create in-place void families and cut the geometry that's under the topo...that way you'll still see what you want to see above the topo...
Fri, Jun 29, 2007 at 9:08:41 AM | invisibility below grade
vblevin
i'm a beginner so i'm not sure what in place void families are, but i'll look it up and see if it works
Fri, Jun 29, 2007 at 9:27:51 AM | invisibility below grade
NightRyder
see the attached image...this is a very basic idea of what im talking about...you essentially create an 'in place component/family' and choose void extrusion or sweep...then you use the 'cut geometry' tool to cut the solid (in this picture the foundation and the wall) using the void...the final product is just an empty area where the void was...it's a pretty simple concept and there should be some tutorials around
Fri, Jun 29, 2007 at 9:38:06 AM | invisibility below grade
#13
vblevin
so if i understand you correctly, you are basically getting rid of parts of the foundation. does it go away for good or can you turn it on and off as needed?
Grade Hatch in Elevation
Wed, Aug 6, 2008 at 12:03:16 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:10 AM
How to model residential garage slab on grade with slope and stem walls
Thu, Oct 10, 2013 at 3:30:52 PM
Pier caps in Grade beams
Mon, Aug 29, 2011 at 2:01:13 PM
Grade Lines in Elevation view not showing
Fri, May 25, 2007 at 5:49:36 PM
Page generation time: 1.6374
