Forums >> Revit Building >> Technical Support >> Void extrusions
Mon, Jun 25, 2007 at 2:43:24 PM | Void extrusions
MrBob
3 Stars: 2 Votes
Have been trying to work with void extrusions.  What am I doing wrong when some of my voids are showing up as orange lines instead of actually cutting the object?  I am using version 9.1
Mon, Jun 25, 2007 at 2:56:55 PM | Void extrusions
broncos4life
3.5 Stars: 11 Votes
Click on "Cut Geometry" then select the solid, then the void.  You can also select the void then the solid.  Don't you keep getting an error saying that there is so solid form being cut by the void?
 HTH
Mon, Jun 25, 2007 at 3:57:02 PM | Void extrusions
MrBob
3 Stars: 2 Votes
Thanks, that helped.  No, I never got any errors.
Wed, Apr 8, 2009 at 4:58:20 AM | Void extrusions
vanson
some time you should take care the work plan  when you creat void form
in your case,i think you should choose again the work plan when you edit the void form
good luck
Wed, Apr 8, 2009 at 5:23:38 AM | Void extrusions
4 Stars: 205 Votes
this post has almost 2 years, LOL....
Creating Solid and Void Extrusions
Thu, Jun 1, 2006 at 10:08:08 AM
Void extrusions showing up orange even when rendered
Fri, Mar 8, 2019 at 1:35:44 PM
creating wall openings with void extrusions?
Wed, Apr 8, 2009 at 4:51:59 AM
Make void extrusion permanent
Wed, Feb 9, 2022 at 6:46:57 PM
Materials wont show under void extrusions
Fri, Nov 25, 2011 at 6:44:17 AM
Page generation time: 0.2003
