Forums >> Revit Building >> Technical Support >> Grids
Fri, Jun 22, 2007 at 11:27:11 AM | Grids
utearch1
Can anyone tell me why some of my grid lines have disappeared in my floor plan view? All the vericals are there, but the horizantals are gone.
 However they show up in my columns layout plan.
Fri, Jun 22, 2007 at 12:03:51 PM | Grids
broncos4life
3.5 Stars: 11 Votes
2008 or 9.1?
Fri, Jun 22, 2007 at 12:26:46 PM | Grids
utearch1
Sorry, 9.1
Fri, Aug 3, 2007 at 10:42:38 AM | Grids
ebtaylor
3 Stars: 2 Votes
having same problem here, using 2008?
anyone?
Fri, Aug 3, 2007 at 10:48:59 AM | Grids
utearch1
What I found was in my exterior elevations, I had dragged my grid lines to one side of the building. When I did this they disappeared in my floor plan view. When I extended them back across the elevation, they reappeared.
 If anyone knows a way around that, let me know. I can't seem to figure it out in 9.1.
Fri, Aug 3, 2007 at 11:18:54 AM | Grids
ebtaylor
3 Stars: 2 Votes
In 2008, I just made a copy of one of my elevations, renamed it, and had my grids & levels intersect. They show up on my plans now and my elevation views I'm using on my sheets are still the same.
Fri, Aug 3, 2007 at 11:44:57 AM | Grids
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
To allow your grid lines to be moved individually you need to toggle the 3D extents to 2D. You can do this by selecting the grid in the view you want to change and then clicking the 3D control. This will change to 2D and you can move the grid endpoints independently in that view. This can also be done for Level markers.
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids
Tue, Sep 1, 2015 at 8:35:46 AM
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
2D and 3D Grids
Wed, Oct 17, 2007 at 10:04:13 AM
Page generation time: 0.2265
