Forums >> Revit Building >> Technical Support >> Coarse section view
Thu, Jun 21, 2007 at 3:22:32 PM | Coarse section view
rsmannino
How do you change the default solid blue hatch in the section view?  I've looked everywhere and can't find it.
Thanks
Rosario
Thu, Jun 21, 2007 at 3:30:03 PM | Coarse section view
broncos4life
3.5 Stars: 11 Votes
Default solid blue hatch for what?  Wall, ceiling, roof, detail componant, filled region...?
Thu, Jun 21, 2007 at 8:15:35 PM | Coarse section view
rsmannino
Everything.  Draw a quick house and make a section.  Than click on coarse detail.  Everything being cut turns to solid blue.   I'm guessing its a default for a course section.
Fri, Jun 22, 2007 at 1:40:59 AM | Coarse section view
Aguel
Aguel Avatar
4 Stars: 8 Votes
It's the default poche material color blue change it to anything you like and you are done.
HTH
Fri, Jun 22, 2007 at 7:34:56 AM | Coarse section view
rsmannino
I know its the default.  Where is the option to change it?
Thanks
Fri, Jun 22, 2007 at 8:19:43 AM | Coarse section view
Aguel
Aguel Avatar
4 Stars: 8 Votes
Go to settings and in the drop down menu click material look for poche material then change its color to anything you like.
Fri, Jun 22, 2007 at 9:00:54 AM | Coarse section view
rsmannino
I'm sorry.  I forgot to state that I am refering to the 3d section box.  Not a section.  I don't see anything about a default section pattern under settings - materials.  Wouldn't it be in a more general option dialog?
If I have a detailed building it doesn't make sense for me to go into each material and change its coarse scale section pattern.
Fri, Jun 22, 2007 at 9:24:59 AM | Coarse section view
sdbrown
5 Stars: 3 Votes
Click Settings, Material, scroll down to poche, modify the cut pattern color as you like.  This is a global setting, not by each assembly type. The section box defaults to this poche material for course scale.
Fri, Jun 22, 2007 at 9:34:10 AM | Coarse section view
rsmannino
oh ok I gotta got it now.  Thanks alot guys
transparent object in coarse view
Mon, Nov 8, 2010 at 12:00:41 PM
Lineweight of steel column in coarse view
Fri, Jan 7, 2011 at 6:25:48 PM
Show brick veneer in coarse view
Fri, Aug 1, 2008 at 11:38:05 AM
Coarse view not displaying for face based models
Mon, Nov 14, 2016 at 8:57:17 AM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Page generation time: 0.7811
