Forums >> Revit Structure >> Technical Support >> Wall Split
Thu, Jun 21, 2007 at 2:39:48 PM | Wall Split
utearch1
Is there a way to split the finish off a frame wall with brick? I have a wall that is brick on framing. At the top is a a cornice. I don't want the brick behind the cornice. Is there a way to take out the top 12" of brick so all I have is the framing and sheathing?
 I know you can do a stacked wall, but was hoping there was an easier way
 Thanks
Thu, Jun 21, 2007 at 2:49:02 PM | Wall Split
broncos4life
3.5 Stars: 11 Votes
Well if you just want the brick to stop before the rest of the wall you go to the Walls Section Property, click modify, and then click the top line of the brick.  Now you should have a lock symbol and just unlock it.  Now you can go to the model and change where the brick ends.
join wall with split region with wall without split region
Wed, Dec 21, 2011 at 8:30:01 AM
Wall Split
Tue, Jul 28, 2009 at 11:52:44 AM
Split Region Wall Foundation Issues
Wed, Jun 1, 2011 at 5:36:25 PM
Wall Split
Tue, Apr 19, 2005 at 2:21:49 AM
Split Facing and Painting both sides of a wall?
Fri, Jan 13, 2017 at 10:52:50 PM
Page generation time: 0.5329
