14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Draw order of linked DWGs
4 Posts No Rating |
I have been having trouble with some AutoCAD drawings I've been linking into my Revit file. The DWG appears on a layer over my Revit walls, making it difficult to tell which walls are aligned properly or even if there are missing walls below the AutoCAD drawing. I've looked up solutions to fixing the draw order but the options aren't appearing for the linked DWG file. Is there any way to correct this or would the only way be to copy my revit elements and paste them over the DWG?
this link may provide some help http://www.revitcity.com/forums.php?action=viewthread&thread_id=7758 HTH
4 Posts No Rating |
Excellent! For those curious the solution is to link/import the file "Current View Only". Thank you very much. Extra kudos for the swift response.
draw order |
Wed, Aug 20, 2008 at 8:26:33 AM
Sending a file with Linked DWGs in it |
Mon, Apr 9, 2012 at 12:04:53 PM
Draw Order in Family Editor |
Wed, Aug 28, 2013 at 3:07:31 PM
draw order in revit 2010 |
Tue, Sep 23, 2014 at 1:24:31 PM
sheet index order with Linked models |
Sun, Mar 13, 2016 at 12:37:27 PM
