Forums >> Revit Building >> Technical Support >> Elements on WRONG Worksets
Wed, Jun 20, 2007 at 2:11:33 PM | Elements on WRONG Worksets
kire68
I've inherted a model that has walls windows and storefront systems all mixed up 3 different worksets. - Workset 1 - Topo - and Rendering. I'm a newbie REVITeer and dont know how to move them all to the proper workset or if it matters. I assume it would matter when i unload the TOPO workset and some of my walls windows and storfront systems vanish.
Thanks for the help in advance -
kire68
Wed, Jun 20, 2007 at 2:49:17 PM | Elements on WRONG Worksets
broncos4life
3.5 Stars: 11 Votes
Well the easiest way is to have one workset on, and do something to isolate the things that shouldnt be there.  Select all of them and the right click and go to "make elements editable"  Then go to the properties of them and change the workset to the correct workset.  They then should disapear if you only have 1 active workset turned on.  You should also be sure to do this in 3D not plan because of things like elevations, sections, and detail componants that dont ride in a workset.  Hope that helps.  Let me know.  Go through that for all 3 worksets or how ever many you have.
Wed, Jun 20, 2007 at 3:52:11 PM | Elements on WRONG Worksets
kire68
thanks - from 3d model view I turned on 1 workset at a time - I had very few things actually required on the topo and rendering worksets so I just deleted the worksets moved everything to workset 1 and recreated the topo workset and moved the site topo and roads to the topo workset.
Thanks for the prompt response.
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Tue, Oct 23, 2007 at 2:36:13 PM
Wed, Feb 1, 2012 at 5:04:15 PM
linked file elements on host workset...help
Fri, May 4, 2012 at 5:46:58 AM
Editing elements of locked worksets
Sat, Mar 7, 2009 at 10:39:42 AM
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
Page generation time: 0.3063
