8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> wall based family
I'm trying to create a wall based family for a Dialysis Box. I have this bathroom with a toilet, grab bars and a Dialysis box, all which need to be viewed in plan. I would like to see that the box is notched into the wall at plan level but also be able to see the grab bars. The problem is that the grab bars are at a height above the dialysis box. I could change the view range to see the notch of the dialysis box but then I wouldn't be able to see the grab bars. Any suggestions? thanks in advanced!
you can use a plan region and set the cut plane to make the grab bars visible HTH
Just a question for coreed...whats HTH? I see that alot on the website and dont know what it is an acronym for. Just curious. Thanks
"Just a question for coreed...whats HTH? I see that alot on the website and dont know what it is an acronym for. Just curious. Thanks" stands for "Hope That Helps"
I thought about using this and tried it...it just wasn't working like I wanted it to. I think I got it figured out or at least comprised. Thanks!
changing type of a family from wall based to face based |
Wed, Mar 3, 2010 at 8:24:37 PM
Is it possible to make a line-based family wall based? |
Wed, Jan 5, 2011 at 1:00:21 PM
Revit 2013 family from wall based to flor based |
Mon, Feb 4, 2013 at 6:56:51 AM
Wall based family sinks into the wall |
Fri, Aug 5, 2022 at 1:50:39 PM
WALL BASED FAMILY |
Fri, Sep 20, 2013 at 3:56:04 PM
