Forums >> Revit Building >> Technical Support >> Wall Finishes
Wed, Jun 20, 2007 at 11:59:24 AM | Wall Finishes
christinea
My problem is that I was attempting to create a Box Beam ceiing using walls (have since changed to a soffit). I placed the walls, but then when attempting to do a rendering, the bottom edge of the wall is not finished. Is there a way to finish the tops and bottoms of walls?
Thanks Christine
Wed, Jun 20, 2007 at 12:14:26 PM | Wall Finishes
broncos4life
3.5 Stars: 11 Votes
Im not sure if there is a revit way to do it, but what I just did was to modify the section properties of the wall, and split the core making the split 5/8" from the top and assigned that layer to be GYP, you could do the same thing to the base...the thing with this is that you would want it to be a seperate wall type from your normal wall that doesnt finish at the top or bottom.  Try that and see how it works for you.
Wed, Jun 20, 2007 at 12:33:11 PM | Wall Finishes
sdbrown
5 Stars: 3 Votes
For rendering purposes just hit the bottom face with the paint tool.
Wed, Jun 20, 2007 at 12:44:00 PM | Wall Finishes
christinea
This took me a little while to get the hang of .... but works great!!
Thanks!!!
Wed, Jun 20, 2007 at 12:48:09 PM | Wall Finishes
christinea
The paint tool is a good idea two, my only question about doing it that way would be when i'm just doing a colored model without actually rendering....renderings take a little longer, and we find it easier to print the colored models for any preliminary designs.
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
wall finishes by room
Tue, Apr 19, 2005 at 11:40:25 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:10 AM
Multiple Wall Finishes.
Thu, Dec 12, 2013 at 11:02:29 AM
Page generation time: 0.9131
