Forums >> Revit Building >> Technical Support >> Resizing Families - Landscaping
Wed, Jun 20, 2007 at 11:30:20 AM | Resizing Families - Landscaping
LUCAS1979
1 Stars: 1 Votes
ok. i need to put together a lanscaping plan; i have bunch of 2D tree-blocks that i will turn into families; my question is: can i make a parametric block/family where entire drawing will scale to the # i'll put in? for exapmle; if my tree (see pic attached) is 10', can i make a parameter size or scale; put (2) and the drawing would jump from 10'to 20'.  Does anyone know if its possible?
Wed, Jun 20, 2007 at 12:34:22 PM | Resizing Families - Landscaping
sdbrown
5 Stars: 3 Votes
Yes, the trick is nesting. create one plant family with your dwg blocks in it, then open a new plant family and load this into it. now it will scale when you change the height of the tree.
Wed, Jun 20, 2007 at 12:42:06 PM | Resizing Families - Landscaping
LUCAS1979
1 Stars: 1 Votes
height of the tree?? the object that i have in mind is 2D lines on a ground plane... ok; i tried it; so i have tree family loaded into another family...what next? where is the scaling option?
Edited on: Wed, Jun 20, 2007 at 1:32:14 PM
Wed, Jun 20, 2007 at 5:21:12 PM | Resizing Families - Landscaping
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Now load this family into your project.
You'll see you can enter a height for the tree.  Whatever height you enter the tree will automatically scale as required...
Regards,
Chris.
need landscaping objects
Fri, Mar 10, 2006 at 4:53:41 PM
Landscape
Fri, Feb 9, 2007 at 7:45:21 PM
LANDSCAPING- TENNIS COURT
Sat, May 20, 2006 at 3:58:13 PM
Scope of the Landscaping file
Mon, Mar 25, 2013 at 4:47:16 PM
Landscaping help needed
Thu, Apr 13, 2006 at 1:08:56 AM
Page generation time: 0.7227
