Forums >> Revit Building >> Technical Support >> Project title text on drawing sheets
Wed, Jun 20, 2007 at 10:30:16 AM | Project title text on drawing sheets
Dav1
I am having trouble with my drawing sheet text. I am needing to show the project title lable in a list style rather than in a row. I'm currently having to add numerous spaces between the parts of my address to achieve this but I was wondering if there was some sort of enter/return function I could use instead?
Can anyone shed any light please??
Wed, Jun 20, 2007 at 5:26:30 PM | Project title text on drawing sheets
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just change the size of your crop box for the label string in the family to be shorter.  Revit will only break to a new line if there is a space or hiphen.  So if you make it short enough only 1 word will fit on each line before revit jumps to the next one.
HTH.
Regards,
Chris.
TITLE LINES ON DRAWING SHEETS
Thu, Apr 29, 2004 at 8:19:42 AM
Title Sheet, Greying Previous Phase sheets
Fri, Jan 20, 2012 at 11:50:57 AM
Sheets showing in Architectural Drawing list but not in project browsers?
Wed, Jan 11, 2012 at 8:08:35 AM
project title block
Tue, Dec 1, 2009 at 2:18:45 PM
View title text
Tue, Nov 16, 2004 at 11:27:33 PM
Page generation time: 7.3911
