20 Users Online (18 Members):
Forums >> Revit Systems >> Technical Support >> New Project set up for MEP
2 Posts No Rating |
If you get a Revit file from the Architect how do you set it up for MEP use i.e. the project browser how do you add Electrical, Mechanical, and Plumbing in the browser
Start your own project in MEP and then link the architects file into yours. Do not work directly on the Architects file or you might find you'll lose all the work you do... Now select elements of the architectural model to "copy/monitor" into your file - the elements selected are generally hosted elements. For instance a ceiling for registers or whatever... HTH.
Regards,
Chris.
One of the guys in our company found this. We have used it for a couple of setups. Hope it helps.
10 Posts No Rating |
We do the same thing. we receive the archtects model. Use that model and link off of the central file... never work in the architects file. When you are done working in your linked file, you can either save (which saves to your local linked vcopy only,) or save to central which saves your work into the central model.
3 Posts No Rating |
http://www.revitgarage.com
www.revitgarage.com |
try download and see my plumbing revitMEP sample on the downloads named "plumbing diagram" i just did it manually tho..
MEP TABS IN 2013 - WHERE? |
Thu, Jul 19, 2012 at 11:03:35 AM
Revit Architecture to Revit MEP |
Wed, Sep 29, 2010 at 2:09:26 PM
MEP link to Architecture slow down |
Fri, Dec 11, 2009 at 3:53:10 PM
Combinng sheets from Revit Arch, Struct and MEP into one CD set |
Mon, Apr 13, 2009 at 2:40:35 PM
Request - Complete Revit Project (Architectural, Structural, MEP) |
Tue, Oct 27, 2015 at 7:35:22 PM
