Forums >> Revit Building >> Technical Support >> Split walls
Wed, Jun 20, 2007 at 9:20:21 AM | Split walls
utearch1
When you split a wall, is there a way to not see the split line in an elevation view? I would like the wall to look like one wall not 2.
 Thanks
Wed, Jun 20, 2007 at 9:38:15 AM | Split walls
broncos4life
3.5 Stars: 11 Votes
If the wall types on either side of the split are not the same type try to "Join Geometry", if they are the same wall type what is the reason for the split (if you dont mind my asking)...but if they are the same type, you can use linework in elevation and make them "<Invisible Lines>" and then they shouldnt show.  The linework tool is 2 to the right of the tape measure tool.
using split face tool on curved walls
Sat, Oct 12, 2019 at 8:21:20 AM
Can't split certain faces
Thu, Dec 6, 2012 at 6:59:31 AM
Split face aournd a corner...
Tue, Aug 25, 2009 at 2:14:22 PM
split face not remembering material - RAC 2008
Thu, Nov 20, 2008 at 3:13:31 PM
Using Split Face
Fri, Jul 12, 2013 at 11:00:40 AM
Page generation time: 3.6457
