10 Users Online (8 Members):
Forums >> General Discussion >> Revit Project Management >> REVIT TO 3D MAX
13 Posts No Rating |
HOW CAN I EXPORT A REVIT MODEL TO A 3D MAX FILE?
you have to be in a 3D view and export that view as a DWG, in MAX use file link create a Revit preset and then you can link the file it works like a charm and the link can stay "alive" so if the revit model evolves or changes your max file can be updated accordingly
OK, but i have another problem. When i export a Revit 9.1 Model to 3D Max, i need to have all the objects grouped by materials, but when i do the export, the objects explode and i can´t select them by materials, because the elements that formed the object are now separate entities and the sistem show me the different layers that form that object. How can i do to have all the objects separate by materials without having them exploded??
Tou can't really. you will need to adjust your layers in Autocad... pain in the neck.
Revit FBX causes 3DS Max to crash |
Wed, Aug 10, 2016 at 6:02:27 PM
render my walkthrough in 3DS MAX |
Tue, Apr 23, 2013 at 2:07:40 PM
MAX TO REVIT? |
Tue, Feb 10, 2009 at 8:38:48 PM
Revit bring into 3ds Max [ 1 2 ] |
Sat, Dec 25, 2010 at 6:24:33 PM
17
Revit to 3d Max FBX [ 1 2 ] |
Wed, Dec 1, 2010 at 8:52:13 PM
17
