12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> title block help
Hi All, i am having tough time trying to create a new title block can any one tell me where and what exactely i am doing wrong. after selecting "a1 metric" under file menu / new / title block finished with adjusting and creating new lines etc... clicked on label on left side menu and since i dont find what exactely what i want in the list of parameters i clicked add and went through the hole process of creating parameter file new and gave a new parameter called SHT means sheet (ie 001 of 005) pls. be reminded that i chose under type as number... then i clicked ok.......ok .........ok....and came back to where i started it from and i found this parameter added to the list of parameters and i selected it and clicked ok and a label appears of screen and i move it to the place i want and save it and load it in to a project and finally this label i created loads along with sheet but does not behave like a label that i can edit it instead it appears like a red coloured question mark that i can not edit..............can any one tell be why and where i made mistake or what is it i have to do to create new labels in title block apart from the listed and editable.......help needed badly. thanks, bjw
sorry i forgot to mention that i am using Revit Building 9.1 Version thanks, bjwson
take a look at this tutorial it should solve all your problems http://www.revitcity.com/tutorials/shared_parameters/ HTH
many thanks man. u made my day thanks again. bjwson
Font on Title sheet absent from project Title Block |
Thu, Sep 15, 2022 at 12:31:26 PM
How to import my title block from AutoCAD? |
Mon, Sep 10, 2007 at 4:25:43 PM
12
In the default Revit Templates i couldnt find revit title block |
Fri, May 23, 2014 at 7:22:23 AM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
project title block |
Tue, Dec 1, 2009 at 2:18:45 PM
