Forums >> Revit Systems >> Technical Support >> skylight placed on sidewalk
Tue, Jun 19, 2007 at 8:33:29 PM | skylight placed on sidewalk
peaslee
attempts to load anypalce but roof plan View unsuccessful,  how would one change settings?
thanks in advance
sp
Wed, Aug 15, 2007 at 2:07:59 PM | skylight placed on sidewalk
charlotte240
charlotte240 Avatar
3.5 Stars: 3 Votes
first, i would suggest you communicate what the problem is exactly.second-- state which version of Revit you use.i think you are talking about "why is there a family" in my "_______"you need to check your host for the family, and re-host the family object (skylight) to a level specific host, such as a roof level, instead of using a generic or general host, such as concrete 8" slab.  let me know if this works, and if this was even your problem... I once had a bar on every generic 8" slab i added, too!!! !!!  wrong host!!!good luck!
CRI
Wed, Aug 15, 2007 at 2:22:54 PM | skylight placed on sidewalk
broncos4life
3.5 Stars: 11 Votes
The majority of all sky-lights I have seen are roof based.  Getting it to change to a different type you would have to copy and paste into a different family type.  I would recomend Face Based if you are trying to get it to attach to a different element other than a roof.  This should also solve your issue of the loading.  If it doesnt, just place the skylight where you can, and rehost it like charlotte suggested.
Wed, Aug 15, 2007 at 3:59:40 PM | skylight placed on sidewalk
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
Have you tried grouping the one item and moving it? I have some floor-hosted families that operate independent of their host once they have been grouped. Wall-hosted families don't seem to do this though, so a roof-hosted may or may not work. Anyone know why my floor hosted-family does this?
Details: AR08, Floor-hosted chair so that they move up and down with the sloped floor automatically. If I group any of them (or a single one) they can be moved away from the floor and the floor can be moved out from under them while all instances not in a group move with the floor/host.
Sorry for the tangent-topic.
rehosting skylight
Wed, Jun 20, 2007 at 8:42:10 AM
sidewalk split topo suface issues
Fri, Oct 7, 2005 at 5:11:42 PM
topographical sidewalk
Tue, Nov 8, 2005 at 4:36:12 AM
Skylight shaft
Tue, Sep 2, 2014 at 4:03:45 PM
ramps with multi slopes
Thu, Apr 23, 2009 at 12:30:57 PM
Page generation time: 1.7331
