11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Site with complex topo
12 Posts No Rating |
I'm doing a project at 2000' above sea level. Do I link the site into the model or vise versa? How exactly do I go about this? Also if my pad is at 2000' do I put level 1 on 2000'? shouldn't it read at 0'-0"? I'm using 2008. Thank You
There are many ways to go about this. Typically, I link the site into my building model if it is a single freestanding structure. But the opposite is true with a multi-building campus (the buildings are linked into the site file). In the site model, I model the site at true elevation (if it is +1200', it is drawn at +1200'), and then using shared locations and project specific level markers my building is modeled at +100' (+0' would work just as easily, its just not the standard drafting conventions I use). If you want the levels to be used for base locations for you pads in your site model simply move them to where they need to be (+1200' or whatever elevations), just check to make sure that the modeled topography does not move with it (if it does move it back to +0').
Site topo street curbs |
Mon, Jul 16, 2007 at 11:58:56 AM
Site Materials in 3d views with a complex site |
Mon, Jul 3, 2006 at 4:32:18 PM
Wall on Topo Site |
Wed, May 28, 2008 at 5:00:38 AM
RAC 2009 - Topo Site Work |
Fri, May 9, 2008 at 3:08:34 PM
level elevation doesn't match elev point in topo / site plan |
Wed, Dec 18, 2013 at 4:05:00 AM
13
