24 Users Online (22 Members):
Forums >> General Discussion >> Revit Project Management >> Sheet´s Tags
13 Posts No Rating |
I usually work in 24x36 in sheets. Sometimes the drawing file does not fit in the sheet and i have to rotate the drawing and the title´s tag also rotates. How can i rotate the drawing without rotating the title sheet tag?
The way I usually do this is by adding a section box to the view if there isnt one, and then rotating the section box. This will rotate the drawing with out reflecting to the model itself, and also shouldnt rotate the title.
Turn on and Rotate the crop region in the reverse direction to what you want the view to rotate. No need for a section box.
Regards,
Chris.
Opps, my mistake, i said section box, but in reality I was thinking crop region. Thanks for the heads up.
THANKS BOTH OF YOU!!!!!!!!!!! YOU REALLY ANSWER VERY QUICKLY!!!!
tags tags tags |
Tue, Mar 20, 2012 at 12:10:23 PM
Tags linked in more than one view |
Fri, Feb 27, 2009 at 6:21:47 AM
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:58 AM
MISSING elevation tags |
Mon, Sep 17, 2018 at 10:55:17 AM
room tags |
Thu, Aug 13, 2009 at 3:54:34 PM
