Forums >> Community >> Newbies >> Door material
Tue, Jun 19, 2007 at 1:04:24 PM | Door material
ferg41268
In my door schedual all of my double doors are blank in the door panel material.  All of my single doors and glass doors are good but no matter what double door I put in, i can't get it to show the material in the schedual.   What can i do the make it work?
Tue, Jun 19, 2007 at 2:23:37 PM | Door material
broncos4life
3.5 Stars: 11 Votes
Material should be something that is put into under the properties of the door, just go to the properties of the door and type in what material it is.  Unless you have it linked to what you actually have the door material to, but either way it should be something input in the properties.
Tue, Jun 19, 2007 at 2:52:21 PM | Door material
ferg41268
I have the properties set right.  You can't just type in whaterver you want in the text box.  You have to select A material for the door panel and then it will show up in the schedual.  I have done that and it works for single doors but not double doors.
Door Panel Material Parameter Selection
Wed, Nov 19, 2008 at 4:34:12 PM
Need Assistance with Door Materials
Fri, Feb 22, 2008 at 1:11:01 PM
Door Schedules
Wed, Sep 26, 2007 at 12:59:57 PM
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Scheduling Door Material with yes/no Paramters
Fri, Dec 16, 2011 at 10:24:05 AM
Page generation time: 4.5102
