Forums >> Revit Building >> Technical Support >> Glass & Window Trouble while Rendering interior view?
Mon, Jun 18, 2007 at 2:03:20 PM | Glass & Window Trouble while Rendering interior view?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I set up a camera in one of the bathrooms in my model and set the rendering settings for interior and did my normal custom settings.  The bathroom has glass doors that I can see through to the bedroom but the glass doors and windows to the deck that would show the exterior/outside are blacked out and I can't see through them at all.  I've checked the materials and their the same as the doors inside that I can see through any ideas as to why I can't see through the doors and windows that would shot outside but I can see fine through the interior glass doors?  Thanks!
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Mon, Jun 18, 2007 at 6:25:42 PM | Glass & Window Trouble while Rendering interior view?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Anyone?  Its weird I rendered other rooms and you can see right through the glass doors to outside just fine...
 LHAA
Reno, NV USA
Mon, Jun 18, 2007 at 6:54:35 PM | Glass & Window Trouble while Rendering interior view?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Two things.
Try setting the doors as "daylights" or change you background colour for your rendering.  Is it set to black?
Regards,
Chris.
Mon, Jun 18, 2007 at 7:43:28 PM | Glass & Window Trouble while Rendering interior view?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
How do I get to the material setting for the glass panel in the glass doors?  I go to the element properties and it has the door panel and the door frame material but not the glass... all I can think of is maybe I messed with the glass material and made it a solid instead of a void or changed the material...
Mr. Spot I tried setting the doors to daylights one door I can see through in one room but the door in the other room is still just black.  Is the background color for rendering in the environment tab?
 LHAA
Reno, NV USA
Mon, Jun 18, 2007 at 11:44:20 PM | Glass & Window Trouble while Rendering interior view?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Is the door you can see through the door you set as a daylight?
Daylights are set instance based not type based...
Yes the background settng is in the environment tab.
Regards,
Chris.
Tue, Jun 19, 2007 at 12:52:31 PM | Glass & Window Trouble while Rendering interior view?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I set both of them to daylights and I still didn't get anything different.  I'm just going to delete the wall and recreate everything to see if that changes anything.  Thanks for helping Mr Spot.
 LHAA
Reno, NV USA
Tue, Jun 19, 2007 at 3:01:47 PM | Glass & Window Trouble while Rendering interior view?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
So some how the glass material got all messed up... I tried fixing it but it didn't work.  Is there a way to load the default materials into the project?
 LHAA
Reno, NV USA
Tue, Jun 19, 2007 at 4:15:21 PM | Glass & Window Trouble while Rendering interior view?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
 LHAA
Reno, NV USA
having trouble with window rfa
Mon, Sep 8, 2008 at 10:37:11 AM
Curtain Wall Rendering Trouble
Wed, Nov 12, 2008 at 1:46:11 PM
INTERIOR RENDERING
Mon, Jul 9, 2007 at 1:02:31 PM
Interior Window Trim
Fri, Apr 20, 2012 at 12:04:29 PM
Interior Rendering
Tue, Aug 9, 2011 at 10:33:14 AM
Page generation time: 2.1300
