Forums >> Revit Building >> Technical Support >> Drawing callouts disappearing when I toggle crop view
Mon, Jun 18, 2007 at 1:54:37 PM | Drawing callouts disappearing when I toggle crop view
Surfrusty777
I'm using Revit Arch. 2008.  Everytime I toggle the crop view off, the drawing callouts disappear.  I can't seem to get them to stay on.  Any ideas?
Thanks,
Surfrusty
Mon, Jun 18, 2007 at 4:39:34 PM | Drawing callouts disappearing when I toggle crop view
LIZARD2806
3.5 Stars: 7 Votes
If I am understanding correctly, then I beleive this is the answer:  I am trying to do this from memory, but if you go to the view that it is being cropped, you should see a black square and a dotted green square (offset to the inside of the black square) denoting your view crop.  If not, enable your "crop region visible" in the view properties.  Anyway, the green outline controls your annotation crop.  You should also make sure that "Annotation crop" is unchecked in the view properties (unless you want it on).  Hope I got this right for you, if not let me know and I'll get you better instructions.
Cheers.
**Using Revit Architecture 2009, 2011, and 2012**
Mon, Jun 18, 2007 at 7:19:39 PM | Drawing callouts disappearing when I toggle crop view
Surfrusty777
Thanks, I tried it but I don't see a green drashed line inside of the crop region line.  I have "crop region visible" checked and "crop annotation" unchecked.  Am I doing something wrong?
Thanks,
Surfrusty
Mon, Jun 18, 2007 at 10:35:21 PM | Drawing callouts disappearing when I toggle crop view
Erik
I understand this is a bug which has been fixed in the latest Built.  Just download the latest.  Problem fixed?
Mon, Jun 18, 2007 at 11:14:46 PM | Drawing callouts disappearing when I toggle crop view
LIZARD2806
3.5 Stars: 7 Votes
I experienced this as well, but it was due to an annotation crop.  Is there a latest build?  Didn;t know that.  If that doesn;t solve your issue, then let me know and I will recreate mine and post it back.
cheers
Disappearing Callouts
Thu, Feb 14, 2008 at 11:36:27 AM
CallOuts Disappearing
Thu, Dec 20, 2007 at 8:48:40 PM
Crop hiding dimensions
Mon, Jul 9, 2007 at 3:32:51 PM
13
Mon, Jul 9, 2007 at 7:09:32 PM
Unrelated Distant Sections Appear in Callouts
Fri, Sep 2, 2016 at 12:05:46 PM
Page generation time: 0.8047
