Forums >> Revit Building >> Technical Support >> CASEWORK ISSUE PLEASE HELP PROBABLY A SIMPLE THING.....
Fri, Jun 15, 2007 at 2:18:14 PM | CASEWORK ISSUE PLEASE HELP PROBABLY A SIMPLE THING.....
jmqrsq
5 Stars: 3 Votes
OK DOES ANYONE OUT THERE KNOW IF I CAN GET RID OF THE ELEVATION INSTANCE PARAMETER OF A WALL CABINET FAMILY? IS THIS A SYSTEM THING THAT CANNOT GO AWAY? BASICALLY I WANT MY TOP OF CABINET PARAMETER TO DETERMINE THE TOP OF WALL CABINETS SO WHEN I CHANGE BETWEEN DIFFERENT HEIGHTS OF THE SAME KIND OF FAMILY IT GROWS/SHRINKS FROM THE BOTTOM AND NOT THE TOP. I AM INCLUDING ONE OF THE WALL CABINET FAMILIES WE BORROWED FORM THE WOODSMITHS INSTITUE WEBSITE THAT WE TWEAKED TO BE OUR OFFICES STANDARD. FEEL FREE TO THROW IT INTO A GENERIC PROJECT AND SEE WHAT I AM TALKING ABOUT. THANKS IN ADVANCE
Fri, Jun 15, 2007 at 3:09:41 PM | CASEWORK ISSUE PLEASE HELP PROBABLY A SIMPLE THING.....
TomDorner
4.5 Stars: 25 Votes
The 'Elevation' parameter is added to your casework family when the family is loaded into the project.  You could try starting your casework families as a 'generic model' then switching them to be in a casework category as I recall theis removes that elevation parameter problem.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Fri, Jun 15, 2007 at 3:36:10 PM | CASEWORK ISSUE PLEASE HELP PROBABLY A SIMPLE THING.....
rkitect
rkitect Avatar
4 Stars: 29 Votes
Negative, I tried this and the elevation parameter was still present.  Could this be a bug?  I tried making a family independent of his and it was behaving the same way.  I've never had this problem before!
Mon, Jun 18, 2007 at 5:03:34 PM | CASEWORK ISSUE PLEASE HELP PROBABLY A SIMPLE THING.....
ementaldesign
ementaldesign Avatar
3 Stars: 2 Votes
Try this one.
Mon, Jun 18, 2007 at 5:10:31 PM | CASEWORK ISSUE PLEASE HELP PROBABLY A SIMPLE THING.....
ementaldesign
3 Stars: 2 Votes
Oh and sorry, I didn't recreate the whole family so there are some things to tweek (i.e. Symbolic Lines...) I just tried to  fix the height issue.
Casework Graphics
Thu, Aug 18, 2011 at 3:53:04 PM
Void cut in nested casework family
Tue, Oct 15, 2013 at 12:46:49 PM
Fatal Error when adding casework tag
Mon, Apr 6, 2009 at 12:38:40 PM
Phantom Casework
Tue, Aug 28, 2012 at 12:25:48 PM
Casework below countertop not visible.
Wed, Jan 27, 2010 at 2:16:58 PM
Page generation time: 0.3803
