Forums >> Revit Building >> Technical Support >> Modify View Title
Tue, Jan 11, 2005 at 7:10:46 PM | Modify View Title
Birdman
I have created a new view title for my title sheets but can not change the default view title Revit uses. I am able to change other defautlt tags in Revit but can not change the default view titles. Any ideas? Birdman
Mon, Jan 17, 2005 at 12:33:17 AM | RE: Modify View Title
Moose
1 Stars: 4 Votes
I think you need to ask yourself a very important question.......do you know how to use the equpiment????
Mon, Jan 17, 2005 at 1:05:17 AM | RE: Modify View Title
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
View titles can be modified in the same way any other revit family is created. Go to--> New Family--> Annotation--> View Title and start creating it to your own specific requirements. You can also open one of the existing view title families and edit one of those to your needs.
Tue, Jan 18, 2005 at 12:37:19 AM | RE: Modify View Title
Birdman
Thanks Mr Spot, I have created my view title but had trouble getting Revit to use it for all new projects. Revit uses a view title called 'M_View Title.rfa' and mine uses a different name. I know I can change it once I have started a project but I shouldn't have to change it every time. The only way I can get around this is by calling my new view title 'M_View Title.rfa'.
Tue, Jan 18, 2005 at 12:42:13 AM | RE: Modify View Title
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you don't plan on ever using it, open the template file and delete the M_View Title out, revit will then use the other as default...
Tue, Jan 18, 2005 at 1:08:58 AM | RE: Modify View Title
Birdman
Tried that and now I don't get a view title at all! Looks like I have to call it the same name as the Revit standard.
Tue, Jan 18, 2005 at 1:34:44 AM | RE: Modify View Title
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the template file create a sheet, drag a new view on to the sheet then change the view title to be the desired title... Then delete the sheet, and save the template file.. This should in effect make your view title the default.
Tue, Jan 18, 2005 at 1:42:20 AM | RE: Modify View Title
Birdman
Brilliant - How on earth did you figure that out? Thanks very much for your help.
Mon, Jan 14, 2008 at 10:01:02 AM | Modify View Title
lbrooksher
Is it possible to change the title style now that the project is already started?  We have many sheets set up and we want to replace it with something closer to our office standard.
Wed, Jun 17, 2009 at 1:17:00 PM | Modify View Title
swalton315
Mr. Spot I didn't find your method to work. Maybe I missed a step.
For a template or already started project you can do the following
One solution is to pick the default one. Edit/new, duplicate. Leave the duplicate what it is called for now. Pick the original and rename it what you want your default to be called. Change its view title family to the right one. Then remove the 2 from the end of the duplicate you madeSet all the old views using detail one you changed to plan by selecting all instances and changing the typeDo the same for all the old desired type to get them to be the new plan ones.
Then purge unused to get rid of the old desired type.
Thu, Oct 14, 2010 at 4:13:26 PM | Modify View Title
#11
mcantwell
mcantwell Avatar
great workaround
Wed, Jun 11, 2014 at 4:04:45 AM | Moose
#12
Hazzel
Quoting Moose from 2005-01-17 00:33:17
"I think you need to ask yourself a very important question.......do you know how to use the equpiment????"
Wow... This may be water under the bridge, but still: I think Moose needs to ask himself a very important question - does he know where he is? (?????)
Edited on: Wed, Jun 11, 2014 at 4:05:45 AM
Wed, Jun 11, 2014 at 7:37:29 AM | Modify View Title
#13
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would hope sine this thread is 9 years old that its water under the bridge
Modify View Scale Parameter
Sat, Dec 3, 2011 at 8:51:44 AM
How to change view title numbering from 1 to 01
Mon, Sep 29, 2025 at 10:02:00 AM
Deleting View Title Extension Line.
Thu, Dec 27, 2007 at 10:06:05 AM
How can I Modify the Viewport title?
Tue, Jun 19, 2007 at 7:28:09 AM
View Title Line Thickness
Thu, Jan 24, 2008 at 1:42:39 PM
Page generation time: 1.4312
