11 Users Online (9 Members):
Forums >> General Discussion >> Revit Project Management >> Windows
4 Posts No Rating |
1. How can you put a window tag on a sheet that the window is above the view line? I have an over head window and it is on showing on the floor plan because my view line is set to 5' and the bottom of the window is at 10'. I don't want to move the view lind but need the annotation on the sheet. 2. How do you tag store frount windows and put it in your window schedule?
For your window in plan you can use a "Plan Region" and adjust the Cut Plane to cut through your window. You will be able to tag it when you do that. As for storefront: I don't think you will be able to schedule it unless it is a window family.
for store front I use a dumb tag, I always create a graphic schedule for them (elevation), they always need to be measured on site.
My Windows are not in my Windows Tab |
Tue, Dec 15, 2009 at 7:02:38 AM
Does Revit 2009/2010 work properly to on Windows 7 |
Thu, Jun 3, 2010 at 4:25:04 AM
12
rendering windows in 2009 |
Wed, Aug 27, 2008 at 8:35:01 AM
Windows 7 and Revit 2010 |
Thu, Nov 18, 2010 at 11:54:09 AM
Need Rakehead windows...... |
Wed, Apr 22, 2009 at 1:15:12 PM
