Forums >> Revit Building >> Technical Support >> site info with the 3D model querie...
Wed, Jun 13, 2007 at 9:37:39 PM | site info with the 3D model querie...
karls1
I have created my 3D house model and have plotted a 3D site successfully, however the aim of this excercise was to add restriction lines (daylighting requirements, height restrictions etc.) on the 3D model so I can see what I have to work with and if I try to add lines on the 3D model they go off on strange dimensions and angles and I can't seem to draw lines on the elevations at all as the programme wants to go back to a floor plan... can anyone identify a tool I need to use or a setting I need to amend? Any help would be really appreciated!!
Wed, Jun 13, 2007 at 11:42:18 PM | site info with the 3D model querie...
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you want your lines to show in 3d then yes you have to use model lines.  Model lines require a workplane.  This can be a reference plane, a level or a face of another element.  Simply set the work plane first then draw you line.
HTH.
Regards,
Chris.
My model info just vanished, when I synched model
Tue, Mar 14, 2023 at 8:29:02 AM
Project level vs. site topography RAC 2008
Tue, Jan 29, 2008 at 2:54:56 PM
Creating a Site
Sat, Apr 10, 2010 at 6:19:21 PM
14
New Revit Site
Thu, Jul 5, 2007 at 10:31:05 AM
Site Materials in 3d views with a complex site
Mon, Jul 3, 2006 at 4:32:18 PM
Page generation time: 1.1543
