23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Door can't cut wall
11 Posts No Rating |
I created a door and when try to place it on a wall i get an error that says "Can't cut instance 36X84 out of wall". Why would I be getting this message? Is it something i did when i created the door? I appreciate any help i can get on this. thanks, Matt
Look at your family & make sure the opening cut is in the right place vertically - it more than likely is. The second possibility is that you are trying to place the door above or below where your wall is. Make sure the floor offset in both the family and the instance are where you want them.
i checked both of your points and i was good, any other possiblities?
post your family and we can take a look to see if there are any constraint problems
Most likely it will be a constraint error in the family. Open it up and change the thickness of the wall to match that in your project. You'll probably find you'll get an error regarding unable to create geometry or something similar. Reconstrain the element so it can flex for different wall thicknesses. HTH.
Regards,
Chris.
wall won't accept door style |
Tue, Aug 15, 2006 at 2:07:53 PM
Door wont cut into in place model wall. |
Mon, May 3, 2021 at 10:21:46 PM
door not cutting wall |
Mon, Apr 6, 2015 at 10:24:32 AM
5'8" wall will not be cut by cutplane |
Mon, Nov 13, 2017 at 3:49:59 PM
DOOR CUT PROBLEM IN PLAN |
Thu, May 4, 2006 at 7:34:59 AM
