19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> problem with walls
as you can see on the first picture i have two walls sticking toogether. when i delete the thicker wall (pic 2) they dont look as they should. i dont know if this is an error. could someone explain this ;]
First question why would you like to do that having two walls side by side? That can be best reperesented in your wall assembly by creating layers of different materials in your wall properties. You might have few reasons why you would like to do that but it has some set back also like when you insert doors or windows it won't cut the two walls but only one of them.
no no i wouldn't delete them normally, i just wanted to show how it looks, cause there is a problem with that thin wall dimensions. yes i know that i will have problems with inserting doors and windows, but i wanted to have thin walls representing tiles only. joining both walls fixes the problem :]
Problem with the walls |
Fri, Dec 27, 2013 at 1:39:28 PM
intersecting inner walls with slanting outer walls |
Wed, Feb 27, 2013 at 7:51:10 AM
Demolished walls hiding proposed stuff |
Tue, Sep 20, 2016 at 5:54:34 PM
Most Bizarre Revit Problem EVER |
Thu, Jan 22, 2009 at 11:43:49 AM
Structural walls in Architectural Model |
Fri, Aug 6, 2010 at 9:51:37 AM
