Forums >> Revit Building >> Technical Support >> Hiding Floor Surface Patterns in Revit 2008
Wed, Jun 13, 2007 at 12:46:17 AM | Hiding Floor Surface Patterns in Revit 2008
kczar
Did Revit Arch. 2008 get rid of the option to turn off Floor Surface patterns?  I need to turn off my tile pattern only, not the floors/slabs.
Wed, Jun 13, 2007 at 1:06:31 AM | Hiding Floor Surface Patterns in Revit 2008
Aguel
Aguel Avatar
4 Stars: 8 Votes
There is major overhaul on graphics override in RA2008 and they can be found in your right click menu now. In your case select the slab then right click you have the option for graphics override select by element  click surface pattern then uncheck visible.
Hope this helps
Wed, Jun 13, 2007 at 1:14:16 AM | Hiding Floor Surface Patterns in Revit 2008
kczar
Excellent, thank you!  I will be sure to check the right-click options in future Smile
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Floor surface pattern not "folding" - how?
Thu, Aug 29, 2013 at 7:41:06 AM
SURFACE PATTERNS ALL CHANGED BLACK???
Mon, Jul 9, 2007 at 1:10:03 PM
Hiding the edges of a topographic surface
Mon, Nov 3, 2008 at 10:44:15 AM
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:25 AM
15
Page generation time: 1.7279
