Forums >> Revit Building >> Technical Support >> Reloading linked dwg
Tue, Jun 12, 2007 at 1:42:30 PM | Reloading linked dwg
hippy
Had to add a new layer to the cad file I am drawing on top of, so I could hide more autocad clutter. But when I reloaded the link 280 diminsions are no longer valid. The dims did not change and all I have to do is put them back but I can't afford this mistake often. Any trick to avoid this nightmare would be greatly appreciated.
Thu, Jun 14, 2007 at 2:57:10 PM | Reloading linked dwg
rkitect
rkitect Avatar
4 Stars: 29 Votes
Trick #1: Don't set needed dimensions until you're absolutely ready for them.
Trick #2: Don't reload the linked DWG until you absolutely need it to be.
Trick #3: Apply for a job at Autodesk and fix their blasted file type incompatibility problems.
Seriously, I haven't found a way to get around this and I share your frustration.  Aside from #3, the other 2 are rules I try to live by when I know I'll need to be linking things in.  One thing I've tried recently is importing one instance of the file and then linking another, be sure you rdimensions are set tot he imported instance so that it doesn't update when you reload the link.
Good luck, and let us know if you find another solution.
Tue, Apr 29, 2008 at 8:08:23 AM | Reloading linked dwg
hippy
I now add lines to my drawings before dimensioning even if the lines are already there in the link to avoid redimensioning (often room seperator lines).
Reloading Linked DWG's
Sat, Jan 28, 2006 at 5:51:05 PM
Reloading Linked Files - Lost Sheet Views
Tue, Aug 23, 2011 at 8:52:01 AM
Dimensioning with linked DWG files
Sat, Nov 12, 2011 at 4:20:06 PM
view rotation vs. reload linked dwg
Sat, May 26, 2007 at 7:17:37 AM
Rotate linked DWG for elevation drawing
Thu, Aug 17, 2006 at 9:59:28 AM
Page generation time: 5.8432
