Forums >> Revit Building >> Technical Support >> Room Tags( why will they not show in certain areas)
Mon, Jun 11, 2007 at 3:44:35 PM | Room Tags( why will they not show in certain areas)
AAbruzzo
I have a Problem?  i have placed rooms and tags into a floor plan.  form this floor plan i have created callouts.  the callouts do not show the room tag and or elevation tag.  it repeats an error message saying that it can not be done, check visiblity.  i have checked visibility and checked all that needed to be checked and it still does not work.I am Puzzled.
Tue, Jun 12, 2007 at 7:56:38 AM | Room Tags( why will they not show in certain areas)
Check your VG again.  Rooms are Model categories, Room Tags are Annotation categories.  Other tags are annotation categories as well.
Fri, Dec 7, 2007 at 2:06:23 PM | Room Tags( why will they not show in certain areas)
twhisker
2.5 Stars: 5 Votes
Did you ever get an answer to this - I have checked my VG settings and EVERYTHING is one - still no room tags in callouts or copies.
Revit Architecture 2010
Mon, Dec 10, 2007 at 6:15:35 AM | Room Tags( why will they not show in certain areas)
K8vitali
i am having the same issue- thank you for the post (this way i didnt have to write it!!! Smile
Crop Regions, Keynotes & Room Tags
Sun, Dec 31, 2006 at 7:12:23 PM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:45:30 PM
Portion of Room tags show up in one plan but all show up in another...
Wed, Mar 19, 2008 at 11:41:50 AM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Room Tags
Wed, Nov 17, 2010 at 11:36:04 AM
Page generation time: 1.3411
