Forums >> Revit Building >> Technical Support >> Link elevation tag to another elevation tag?
Mon, Jun 11, 2007 at 12:40:51 PM | Link elevation tag to another elevation tag?
taylormeg
So one of the Revit n00bs on my team put a bunch of different elevations on the plan when she should have just added more views to a single tag.  Now we're trying to clean up the plan, and wondering if there's an easier way to migrate or link the 2 elevations together without losing all the detailing we've already done.
Any ideas, or do we have to do it the hard way?
TIA,
Meg
Mon, Jun 11, 2007 at 2:57:41 PM | Link elevation tag to another elevation tag?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
As far as I know you can't merge two elevations. You can however go ahead and add the other elevations to the symbol. This will create new views. You can then use "Copy to Clipboard" and "Paste Aligned" to transfer your detailing to the other views. This may be a little tedious if you have a lot of detailing to transfer, but the paste aligned command will place them in the exact location that they were on the original view. HTH
updating/changing elevation tag types
Wed, Mar 19, 2008 at 9:49:46 AM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
Elevation tag
Thu, Nov 1, 2007 at 3:06:21 PM
if I happen to put two elevations on different sheets on the same elevation tag
Wed, Jan 12, 2011 at 3:00:58 PM
Elevation Tag
Mon, May 29, 2006 at 7:29:36 AM
Page generation time: 0.4894
