19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Curtain wall doors
We cannot get the curtain wall doors to load on our computers. We cannot get any doors to work on our curtain walls. Does anyone know how to fix this?
Curtain wall doors cannot be placed the same way as normal doors. You need to tab select the system panel of the curtain wall, then change its type to the required door in the pull down menu at the top left.
The curtain wall doors are not listed under the doors category, they are listed under the curtain wall panels...
39 Posts No Rating |
ok so i am designing my own curtain grid system. I am placing doors into the curtain wall as "curtain wall single glass." You can see three of them in the middle of this curtain wall. However, notice they all face the same way and open the same way. I want to change the orientation so that it looks like 1 set of double doors and then a third door next to it. how can i do this? see attached. thanks!
You can flip them in a plan view as you can do with normal doors.
Curtain wall doors wont center up |
Mon, Oct 12, 2009 at 4:28:48 PM
No curtain wall doors on curtain walls! |
Sun, Nov 22, 2009 at 7:10:58 PM
tagging curtain wall doors |
Mon, Jul 30, 2007 at 3:14:11 PM
Storefront Curtain Wall Doors |
Fri, Feb 1, 2013 at 10:51:37 AM
Curtain wall / doors problems |
Tue, Aug 15, 2006 at 2:06:03 PM
