Forums >> Revit Building >> Technical Support >> Actual Window Head height
Thu, Jun 7, 2007 at 5:44:29 PM | Actual Window Head height
daleyy
I trying to set up windows with a parameter that represents the Head height of the window.  No mater what I do I cannot get the actual head height (bottom of Header).
When creating a new window from the Revit template, I get Height which is also the cut in the wall which is also in reality the rough opening of the window and Sill Height.  When I place this as simple as it is in a wall in a project I get 2 instance parameters called Sill height and Head Height.  Both move the window.  This is what I want.
When I go to place my actual window frame in the family, and set the Height of the window, and then place it into the wall the Head Height is displayed incorrectly.  I found out that the Head height that appeared is based on a hidden formula of Sill height + Height.  The incorrect thing that I noticed is that the actual head height of the window is the sill height + rough height.
How can I get this to appear correctly?  I need to have a instance parameter that is called Head Height that is related to the rough opening height of the window.  If I enter 8'-0" in this parameter I get 8'-0" from level to top of rough opening of the window.  I also want this height to be the origin height of the window.  So if I am setting windows in elevation I am setting the head height say at 8'-0" again.
 I really need this to work this way.  I had this issue a while back for another firm I was setting up but now I am having the same issue with it on this firm.
 Thanks
DaleW
head height of window
Thu, Nov 3, 2005 at 5:19:14 PM
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
Sill and head height of windows - in the dimension I can only show the actual
Sun, Aug 18, 2024 at 1:01:15 AM
window is 1" off of head height
Sat, Aug 17, 2019 at 1:15:53 PM
Pella Window Head Height Schedule Problem
Mon, Mar 12, 2007 at 5:42:21 PM
Page generation time: 1.5194
