Forums >> Revit Building >> Technical Support >> text in a dimension???
Thu, Jun 7, 2007 at 3:47:52 PM | text in a dimension???
ebtaylor
3 Stars: 2 Votes
Is it possible to create text under your dim line similar to autocad? Where your text is part of the dim., other then using the prefix or suffix. If not, this would be a good wish list item !! thanks
Thu, Jun 7, 2007 at 3:52:46 PM | text in a dimension???
TomDorner
4.5 Stars: 25 Votes
Not possible other than via the prefix/suffix option.  Many have asked for this in the past.
Tom
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
Page generation time: 0.2712
