Forums >> Revit Building >> Technical Support >> Creating tags
Thu, Jun 7, 2007 at 2:19:20 PM | Creating tags
yelodayze
Im currently using Revit 2008.  At my firm we use Revit but we whave started to do our details in Autocad and just are going to create a pdf and insert it into our 24 x 36 const. doc. set. My question is how do I create tags; detail, sections, etc....without having it associate to something and just have it refer to my details on my detail sheet created in autocad.  Any thoughts?
Thu, Jun 7, 2007 at 3:58:57 PM | Creating tags
TomDorner
4.5 Stars: 25 Votes
Try creating drafting views in your Revit project.  They can simply be blank views and for tracking purposes name them with the detail number in yuor AutoCAD set.  i.e. 3/A2.  Then when you are placing a section check the box called reference other view and choose your drafting view as the view to reference.  You only get one shot at this and that is before you click to place the section.  If you happen to place the section and want to change it to reference other view, you have to delete the section mark and start over.  I don't think this works for elevations though, but may work for plan callouts.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Creating custom tags & custom categories in Schedules function
Thu, May 26, 2005 at 6:57:27 PM
Creating custom tags & custom categories in Schdules function
Thu, May 26, 2005 at 6:42:45 PM
Accessing Room Data in Door Tags
Mon, Jan 28, 2013 at 9:42:59 AM
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:05 PM
Creating Furniture Tags Custom
Tue, Feb 11, 2014 at 5:29:58 AM
Page generation time: 1.8135
