19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Attaching a Tag to an object when it is inserted into Drawing
1 Posts No Rating |
I do a lot of As-built plans, so I locate where I take pictures.
I would like to know how to get a Tag to automatically number in sequence when you place it with an object. When you place a door, it adds a door tag and it numbers each door. I would like a Photo reference bubble that will count automatically as I insert each bubble.
If I could get the Mark ID to count how many bubbles I add it should work. But as of now the mark does not change each time I add a bubble, like it does when you add doors. Thanks I am using revit Architecture 2008
Edited on: Wed, Jun 6, 2007 at 3:30:12 PM
From memory doors, windows and parking tags are the only elements that are automatically sequential (maybe not parking would have to check)... This is something built into these tags templates that enables this, I don't believe its possible in other family categories...
Regards,
Chris.
What controls Dimension style of inserted Labels? |
Tue, Aug 6, 2013 at 12:37:46 PM
Shared Parameters with multiple families...Help |
Mon, May 23, 2011 at 12:37:24 PM
Place tag by clicking object then tag location |
Thu, Oct 18, 2012 at 7:17:17 AM
DRAWING ID TAG |
Wed, Dec 21, 2005 at 9:14:28 AM
Tag crown molding (wall sweeps) |
Thu, Mar 26, 2015 at 8:38:34 AM
