17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Rendered Walkthrough
23 Posts No Rating |
I tried to render a walkthrough with 500 frames at 5 fps 150dpi. I was able to export it as a hidden line and shaded view but when I try to playback the rendered walkthrough I have the first frame and the rest are just fuzz like tv static. What could be wrong? Jen
I am using Revit Architecture 2008
What codec did you export to? As it sounds like the codec you used is bodgy. I generally always export walkthroughs as either jpg frames or uncompressed avi. Then I do the compression afterwards using Camtasia or Move Maker.
Regards,
Chris.
Im not sure what codec I used, I think I left it uncompressed frames. I did figure it out though. I was cancleling the export before it was done to make sure that it was working before I let it run all night. I let it run anyway and this morning it looks good. Thanks
Rendered walkthrough is blurry |
Tue, Dec 2, 2014 at 1:41:44 PM
best way to do a rendered Walkthrough video?(Student) |
Mon, Sep 19, 2016 at 6:31:24 AM
Walkthrough in realistic view, not rendered |
Wed, Aug 27, 2014 at 12:00:38 PM
rendered walkthrough? |
Mon, Jan 2, 2012 at 1:43:19 AM
How Do I set the DPI for a Rendered Walkthrough ? |
Mon, May 28, 2007 at 11:54:37 PM
