9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Removing Stair Balusters
9 Posts No Rating |
This is probably a simple question but I have a stair between two walls and do not need the baluster portion of the railing. How are stairs with handrails created without balusters.
Thanks
Form
admin
never tried this but I think you would be able to do it by editing the railing type and just setting all the balusters to none.
Hiroshi Jacobs
The Catholic University of America |
3 Posts No Rating |
Thanks
FormAfter you make your stair you can select the handrail only and delete it.
9 Posts No Rating |
Thanks,
I just edited the properties and removed the parts I din't need.
Mike
62 Posts No Rating |
if you search the AUGI revit forum for Phil Reed's posts the guy is an absolute master with stairs and inovative uses for the balauster families. If your lucky there may even be some .rvt's posted along with the renderings for you to play with and learn from.
1 Posts No Rating |
"if you search the AUGI revit forum for Phil Reed's posts the guy is an absolute master with stairs and inovative uses for the balauster families. If your lucky there may even be some .rvt's posted along with the renderings for you to play with and learn from."
stair railing baluster properties not consistant with deck rail |
Wed, Sep 3, 2008 at 11:08:32 AM
Balusters not connecting to stringer |
Wed, Mar 24, 2010 at 4:37:37 PM
2015 use baluster per tread on stair (with no top rail?) |
Thu, Sep 3, 2015 at 4:50:57 PM
Balusters |
Wed, Aug 13, 2008 at 2:39:04 PM
Balusters / Railing / Stairs - Custom? |
Thu, Nov 9, 2006 at 7:53:09 AM
