Forums >> Revit Building >> Technical Support >> covered stairs
Tue, Jun 5, 2007 at 8:14:28 PM | covered stairs
aidanshoku
So.  I'd like to make stairs reminiscent of a green house.  This is what I have so far; what I can't figure out is how to make a roof that slopes along with the stairs.  Also, I was hoping to make the roof curved, which I know you can do by extrusion, but again, couldn't figure out how to get it to follow the line of the stairs.
Tue, Jun 5, 2007 at 8:42:07 PM | covered stairs
framerman
4 Stars: 13 Votes
You'd have to create a few roofs there to achieve it. To make it follow the same slope as the stairs, it's usually easiest to make the roof by extrusion and use the edit lines to match the stair slope. You can trim away the excess in plan view if things overlap what you want them to be. Not quite sure how you want a curved roof on those stairs though.
When all else fails, you could do a mass and convert to roof.
Wed, Jun 6, 2007 at 2:55:45 AM | covered stairs
ale02
ale02 Avatar
3 Stars: 3 Votes
I think, you can try to built roof family using blend for the stair and another family using sweep in landing.
by my theory, it should work with a bit adjustment at the edge.
Good luck. and let me know if it don't work.
Life is never easy but nor it should be complex. Just stay simple Smile
Roof Covered Entry Problem
Mon, Jan 31, 2011 at 1:58:30 PM
Demo'd stairs still hide new stairs
Sat, Dec 17, 2005 at 9:04:18 AM
transparent filled region not showing up over stairs
Wed, Mar 12, 2014 at 3:39:41 PM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
Page generation time: 0.0633
