Forums >> Revit Systems >> Technical Support >> Image Import Problems
Tue, Jun 5, 2007 at 12:21:01 PM | Image Import Problems
ericrktek
We are running into some issue when trying to import images into Revit.  Problem is that Revit seems make the default resolution for the jpeg as 72 dpi, and adjusts the size of the image to whatever in a conversion process to account for the images import resolution.  This is a significant and seemingly unnecessary pain.  We have a lot of images and scans that we incorporate into our drawings for presentation and otherwise that need to be at a lot higher resolution than 72 dpi.  Is there any kind of preference or global control for this that can be adjusted?  How are other folks handling this problem.  Do folks just save their drawings at or 288 dpi and scale accordingly in Revit?  Thanks in advance for your assistance.
Eric
Just upgraded to Revit 2008
import image 2008
Sat, Oct 18, 2008 at 4:44:38 PM
ACAD Import Problems (With Blocks)
Mon, Jan 12, 2009 at 5:26:46 AM
IMPORT BACKGROUND IMAGE TO RENDER IN RAC2009?
Tue, May 6, 2008 at 12:25:34 AM
Revit-Autocad Import/Cad Resolution problems
Tue, Aug 11, 2009 at 4:06:54 PM
Autocad Import Problems
Tue, May 5, 2009 at 1:55:33 PM
Page generation time: 2.4229
