26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> REVEAL help, reveal turning a corner at end of wall??
2 Posts No Rating |
revit 9.1 I have attached a picture that shows my issue, i have placed my wall reveals on part of the wall and i am trying to get them to turn the corner, but it is not allowing me to place the reveal on the end. the wall is a concrete wall with two layers of gyp bd. How can this be done? I would appreciate Thanks
Select the wall sweep, then in the options bar you will see a choice for "change sweep return" select that than hit the edge of your reveal, this will add a grip that you then can drag the reveal back to wrap into your opening. For more complex conditions I recommend an inplace sweep that you sketch the path and cut out of the wall.
First, make sure that you wrap the exterifor of the wall finish at inserts[found under the type properties of the wall]. Next, click on one of the sweeps, on the options bar choose 'change sweep returns' click on the sweep and set the return angle to 90 or whatever you need. Then drag the blue grip of the return sweep and drag it to the end of your wall return. Edit: Scott beat me by 14 seconds!
Edited on: Tue, Jun 5, 2007 at 2:18:26 PM
Tom www.reviteer.com http://twitter.com/Reviteer |
2 Posts No Rating |
thanks guys
how to add a self made reveal to a wall while edit wall types? |
Sat, Feb 12, 2011 at 10:53:31 PM
Wall Reveal-Please HELP!!!!! |
Fri, May 26, 2006 at 9:12:01 AM
REVEAL QUESTIION |
Wed, Mar 9, 2005 at 5:07:49 PM
Wall Reveal by Face in 2010 |
Wed, Apr 7, 2010 at 10:20:06 AM
how to angle end of wall |
Wed, Jul 23, 2008 at 1:37:15 PM
