Forums >> Revit Building >> Technical Support >> Simple Question regarding walls
Sun, Jun 3, 2007 at 1:17:45 PM | Simple Question regarding walls
RyanJosephDC
Hello everyone!  I am new in using Revit and I have a simple question.  I would like to put an opening to a wall and I am using the "opening..." command in the modeling but the opening is only in the square or rectangular shape.  I would like to ask how can I customize an opening on the wall such as an arc (same like a garage opening) or any kind of customized shape.  Hope to hear from you guys soon.  Thanks in advance.
Sun, Jun 3, 2007 at 3:41:19 PM | Simple Question regarding walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What version of revit are you using?
 Instead of using wall opening use opening by face, then you can draw the sketch of what you want.  Alternatively, you can create a family for the opening OR you can edit the profile of the wall (by selecting it and choosing edit profile at the top of screen)
Regards,
Chris.
Mon, Jun 4, 2007 at 9:20:23 AM | Simple Question regarding walls
RyanJosephDC
Thank you ChrisSmile  Your reply really helped me a lot btw, the version of Revit that I am using is release 9.
thank you again,
Ryan
Simple Question
Sat, May 29, 2010 at 4:54:11 AM
Very Simple question regarding openings
Sun, Jan 2, 2011 at 8:18:11 PM
Hello every one, simple Question
Fri, Apr 11, 2008 at 10:27:27 PM
Newbie here...quick siding question
Sun, Feb 17, 2008 at 3:24:25 AM
Dimension Question
Wed, Nov 23, 2011 at 11:41:34 AM
Page generation time: 1.4007
