18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Levels in Sections
69 Posts No Rating |
I think somehow that I've managed to delete my level lines in my section rather than turning them off. Is there a way to re-paste my existing level lines into my sections? Right now, when I add level lines, they become new level lines.
Basically, is there a way to copy a level or even put in a new level and associate it with a current level?
If you haven't deleted the levels, then the level lines still exist. There are several things you may have done. 1 - Did you temporarily hide them? Reset your hide to show all. 2 - Did you turn them off in this view? - Check your VG. 3 - Did you pull them outside of your crop regions? - Pull your crop regions out on both sides and you'll find them. 4 - Did you hide the annotation in view? Roll over the area where the level line should be and it will become visible then set it to show in view.
Edited on: Fri, Jun 1, 2007 at 11:05:24 AM
Thanks for the reply, it turns it out it was #3. The levels were moved way to the right in one section and it had moved them all to the right in the other sections.
Levels, Disappeared. [ 1 2 ] |
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor and Ceiling Levels |
Sat, Jul 15, 2006 at 9:38:55 PM
VISIBILITY OF LEVELS |
Tue, Jul 13, 2010 at 12:45:49 PM
SECTIONS AND LEVELS |
Mon, Dec 20, 2010 at 3:05:06 PM
levels in sections/elevations |
Tue, May 9, 2006 at 11:18:21 AM
